MS Office - Blurry fonts when switching from Dock
8 Jan 2007
Hi,
I have a weird issue.
I use a laptop & a USB 3 Docking station.
If I boot up into the laptop and then switch to the dock while the laptop is on, a lot of the fonts go smaller and blurry.
If I sign out and back in again it fixes the issue, but this is a little annoying.
Does anyone else have experience of this?
Thanks
skeletonw00t;30491891 said:
It's a targus usb 3 dock.
Yes theres an external display connected by DVI - it's also 1080p same res as the laptop.
Scaling is 100%
I would double check this is the case because what you describe is exactly what happens when DPI scaling is changed during a session.
Check that the scaling matches when both undocked and docked.
