MS ONEDRIVE : Strangeness
18 Oct 2002
Cambridge, UK
Hi,
So I went to look in my ONEDRIVE as now I only seem to have access to something called Personal Vault, if I login to ONEDRIVE online I can still see all my normal ONEDRIVE files :confused:
What's going on here then ;) ?
Thanks
HEADRAT
Told OneDrive to only keep files in the cloud to free space up?
Also make sure your OneDrive is logging into the same account as the one your using on the website.
Have you got all the folders set to be available on your PC's Onedrive? Check out the settings and check what folders are ticked.
Well I hadn't changed anything, as you correctly suggested it had deselected all of my folders, ticked them all again and they are back :)
Thanks
