MS VB 2008 noob here, need sum help plz
29 Aug 2011
UK
Hey guys, I have made a program on VB 2008 that can make calculation.
I want to make the password box appear first with the form not visible but after I enter the correct password(in 3 attempts). it only happens when I press the start button here the password box would come up.
any help plz?
'Assuming you have a form called frmMain and it is set to hide at startup.
Dim strPassword, strEnterPassword As String
Dim intTries As Integer
strPassword = "sausages"
intTries = 0
Do
intTries = intTries + 1
strEnterPassword = InputBox("Please enter the password. Attempt: " & intTries)
If strEnterPassword = strPassword Then
MsgBox ("Your Password is correct")
frmMain.Show
Else
MsgBox ("Password Incorrect. Access Denied!")
End If
Loop Until intTries = 3 Or strEnterPassword = strPassword
Couple of things,
1.Your variable for "Tries" is declared as a "String" (it should be Integer).
2.By the naming I guess you have a label called "lblAccess"? what does this do?
Hmm well if I try putting Integer in and debugging it it gives me a error, leaving it as string works out.
the lblAccess wud be visible if I enter the correct password, and the form will appear up.
Conversion from string "sausage" to type 'Integer' is not valid, it highlights the password part. yeh lblAccess is a created label.
yep, so that is a data type mismatch error(you are trying to use both string and numeric data on a string variable)
Try my code, with frmMain.Show replaced by lblAccess.Visible = True
Thanks, I tried debugging but the password dialog still doesn't appear first, dont know where im going wrong. A real noob here lol
Have you set the startup object correctly?
When the project starts, it should execute the above code procedure first.
EDIT:
I think it is in the IDE, project options section.
Would this be right, just uploaded a pic:
I've selected the Set as Startup project, ran it but still doesnt show up first.
Have two forms. A main one and a startup one that shows the password entry box. Then on the first form show the second form and use Me.hide to hide the startup one.
