MS Virtual PC vs VirutalBox
5 Jan 2004
I wanna learn linux but until i'm use to it i still want to use vista. So i want to use a virtual machine to install linux and use vista for tutorials and day to day use. So which program is better to use to install a virtual copy of vista.
Your question is a bit muddled. If you mean Linux host and Vista guest then the answer's obviously VirtualBox, Virtual PC doesn't run on Linux.
If you mean Vista host and Linux guest then the answer's still VirtualBox, it's the better virtualisation package :)
Virtualbox doesn't seem to like WiFi. I've gone to Wired now, so I couldn't tell you if this has been fixed in the latest version.
Ok thanks, I have used an older version, I'll probably go back to that as that didn't affect the wifi.
Hopefully it will be fixed in the next version.
