I've just downloaded an application form for a new job and it says on the website that I can either fill it in by hand or in Word, it however states that if I use word I cannot alter the layout.
Problem is when I type into the tables as soon as I press enter for the next line it expands the table changing the layout. I've done forms in the past where this doesnt happen.
Does anyone know how I can disable to tables changing size when I press enter?
This is the form with only one word:
And this is it if I try to use the next line:
As you can see the cell has expanded changing the layout and pushing stuff off the bottom of the page :/
I'd be very thankfull if anyone knows how to fix this
