As you can see from the image above, whenever I open MS Word, it maximises, but leaves a portion of the screen visible with all the status stuff behind the taskbar.
Easy one.
Drop your resolution down slightly from whatever it is now.
Launch Word and make sure it's maximised OK, then close it.
Change your esolution bak to normal and launch Word again - should be sorted.
Apps can sometimes lose track of where the corners of the screen are and that should help it remember
