MS Word Ribbon Help
29 Sep 2004
Wilt of the Shire
Not sure what I've done but every time I use MS Word now the ribbon is collapsed. There are 3 dots in the upper right that restore it when you click on it but it collapses again when you go back to the document.
I've looked online and found several guides to restore the ribbon but they didn't make it show all the time. I'm sure I've just clicked something somewhere but not sure what!
So from the Options menu.
Click on Customise Ribbon.
Under the "Customise the Ribbon" section, use the "Reset" drop-down menu and select the Reset all customisations option.
If this doesn’t work then reinstall Office or try Libre Office.
Life is too short :D
Life is too short and as soon as my MS365 sub runs out I'll be jumping ship, I mainly get it for the 1TB storage but I hardly use that. Going to try Libre Office as I've never used it before.
Anyway, I managed to get the ribbon back so I'll post here in case anyone else comes across this. It's Shift+Ctrl+F1 and then you should see a pin on the right and that's it, MS can't even get that right as they say it's Ctrl+F1 on their support page!
