MSCONFIG problem can't change it
12 Aug 2011
Seems my MSCONFIG is playing up
Noticed the last 3 days its been booting up in selective start up mode with everything ticked to start.
I try to select Normal boot with only what I want ticked but after every reboot its back to selective with everything.
Can anyone help me fix this please ?
Thanks
Running Win7 and MINT dual boot.
Selective is normal behaviour if you have adjusted any service to Disabled or any other statrup parameter to anything but 'Default'
You cannot have a normal startup if you have disabled a service it wants to run normally in the services console.
Selecting Normal would re-enable all startup items.
Leave it on selective, select what you want to startup and untick what you do not and leave it.
The Selective option will then have a Square selection in it's tickbox (meaning only some items are selected and not all)
No reason why on next reboot any of your options should change, just do not re-select normal as it will clear your selections.
