garyh said:Having installed Vista Business via MSDNAA I noticed it only gave me the option to install 32bit and not 64bit.
Is this just because of the ISO image I have, or is it because of the licence key I received.
Thanks![]()
Thanks![]()
ScoobyDoo said:Theres two MSDN images to download, a 32bit and a 64bit version, sounds like you downloaded the 32bit. The licence key is the same for both.
BeatMaster said:Can you swap between 32bit and 64bit using the same key without any problems? Does the key take on the role of an retail key rather than an OEM?
BeatMaster![]()
ScoobyDoo said:Using my msdn subscription, ive been able to swap between the 32bit and 64bit versions using the same key. Basically my subscription gives me authority to use vista on 10 machines, so it doesnt matter if they are 32bit or 64bit.
