MSFS 2020
16 Jul 2023
UK
My Flight Sim seems to not be running as it should, I am not very good with pc's to be honest so coming here for some help as to what could be wrong, or if I need to make an upgrade/downgrade to get the best performance, or if my parts are not the best match for each other. Thanks. Specs are as Follows:
MSI B450 Gaming Plus MAX
AMD Radeon Sapphire Pulse 6800
TX750M Power Supply
4 x 8GB Corsair Vengeance RGB Pro DDR4 3000 MhZ
AMD Ryzen 7 3700x (Stock Cooler)
Corsair 465x RGB Case
Corsair MP510 1TB SSD
Seagate 2TB HDD
Low FPS even on Low settings, stuttering when panning camera, i just feel my hardware should be performing a lot better than it is and ive tried possibly everything to fix it and nothing is working. Thanks
Have you done much troubleshooting? Your PC should be able to run this game without problems.
Do you get an appropriate score for your hardware, in CPU and GPU benchmarks (e.g. cinebench and 3D Mark)?
I have followed nearly every graphics video and nothing seems to improve it. I will download cinebench and let you know. Thanks
Cinebench Single core comes out at 1250 pts and multi core comes out at 11112 pts the game is installed on my SSD with 266 GB Free.
