? MSI 2080 Ventus V2
Permabanned
3 Nov 2018
The other side of The Gap
Does anyone know what is different about the Ventus v2?
I've JFG'd and no info, only vendors selling it.
I found the differences about RTX 2080 Ventus and RTX 2080 Ventus V2, V2 used binned TU104-400A-A1 chip, it has factory OC, the PCB is custom and card is shorter measured 255 x 127 x 42 mm and it is lighter 856g weight, the cooler seemed shorter and also removed USB-C port. RTX 2080 Ventus used normal TU104-400-A1 chip, it did not have factory OC and probably used reference PCB measured 268 x 114 x 42 mm and weight 955g, the cooler seemed bit larger than V2 and V1 has USB-C port.
TU104-400-A1 are Normal Chips (no factory OC permitted).
TU104-400A-A1 are Binned Chips (factory OC permitted).
Both support manual overclocking
https://www.techpowerup.com/gpu-specs/msi-rtx-2080-ventus.b6231
https://www.techpowerup.com/gpu-specs/msi-rtx-2080-ventus-v2.b6674
https://www.msi.com/Graphics-card/GeForce-RTX-2080-VENTUS-8G/Specification
https://www.msi.com/Graphics-card/GeForce-RTX-2080-VENTUS-8G-V2/Specification
RTX 2080 Ventus V2 look like a bargain card for £650 or less make Radeon VII look bad.
It very hard to find any RTX 2080 Ventus V2 reviews!
Yeah, sorry I forgot my manners and never said thanks too.
So, thanks! :cool:
I didn't commit anyway, waited to see what Navi was like and now I'm thinking of going with a Super version if they're any good on release.
