- 2 Feb 2010
- London
Hi,
A friend has recently bought a new MSI R5850 Twin Frozr to run in CF with his Gigabyte 5850. There are some issues with it:
1. The sceen wobbles randomly when opening or closing applications, with lines across the screen.
2. Fan speed was 54% regardless of load (now fixed using ati overdrive to reduce fan speed).
System specs:
i5 750 (stock)
4 GB XMS3 1333
Asus P7P55D-LE board
Gigabyte stock 5850 1GB
MSI 5850 Twin Frozr (just added)
Win 7 64 bit home.
700W OCZ PSU.
Basically he wiped the drivers using driver sweeper and uninstalled all the ATI software.
Added card and Xfire bridge, switched on and installed drivers and CCC again. Then added the Open CL and CAP profiles as well.
The above problem now persists...
System specs:
i5 750 (stock)
4 GB XMS3 1333
Win 7 64 bit home.
700W OCZ PSU.
