Hi.
I took advantage of the Xmas deal to upgrade my old nvidia 9800gtx to a shiny new 5850.
The card appeared to work perfectly, connected to my 22" w/s monitor using DVI, until I decided a week or 2 ago to update the driver from the 8.x one shipped with the card. Upon updating the driver to anything beyond 10.x the card fails to send a signal to the monitor (blackscreen)
Safe mode then works.
As part of the "I'll fix this " process I have performed a clean installation (wiped HDD) of Windows 7 Pro x64.
The only "solution" I've found so far has been to change from DVI to d-sub connection which then works, though with slightly lower image quality, obviously this isn't a long term solution.
Any suggestions?
System
q9300 @3ghz
4Gb Geil @ 960mhz
corsair SSD, 2x mechanical HDD 500Gb + 2Tb
DFI bloodiron P35 t2rl
crucial realpower 700W
win7 pro x64
Any suggestions?
System
q9300 @3ghz
4Gb Geil @ 960mhz
win7 pro x64
