I hope Im posting this in the right section :s
Im not very tech minded,but will try my best to explain my problem and understand any advice given.
I recently upgraded from a sapphire 5770 to the msi 5850 twin frozr that was on special offer last week. At the same time,I upgraded to a 700w psu.
Since installing,I now get frequent framerate drops in BFBC2. It will be playing lovely one minute,averaging around 70fps,then it suddenly drops to 15-20 fps for around 20 seconds before jumping back to normal. I used msi afterburner to log the framerate and gpu usage etc.. It happens about every 3-5 minutes and actually has a pattern for it. (in the graphs,you know) The gpu usage drops in sync with the framerate.
Ive tried rolling back the drivers and have used all of them going back to 10.4,but no fix. Ive reinstalled the game,just to make sure it wasnt conflicting with the new hardware.
Ive also tried playing with the power settings for my cpu and pcie. Turned 'cool and quiet' off etc..
Ive even tried a fresh install of w7 home premium.
So,Im now at a loss of what to try next,apart from open one of these RMA things.
Im not 100% on my system specs to post up,but have just done this cpuz thingy if that helps..
http://valid.canardpc.com/show_oc.php?id=1688823
(Just noticed that my core speed of the gpu is 399mhz,is that normal?)
Any help or advice on this would be appreciated.
