30 Dec 2011 at 13:33 #1 lackofskill lackofskill Associate Joined 1 Oct 2010 Posts 97 dose any1 know where i can get a water block for my 2 msi 6950s ?
30 Dec 2011 at 13:46 #2 Cleeecooo Cleeecooo Soldato Joined 8 Oct 2010 Posts 22,382 Location Purley - Croydon http://www.coolingconfigurator.com/
30 Dec 2011 at 14:04 #3 ThePengu1n ThePengu1n Associate Joined 24 Aug 2011 Posts 723 Location Nr Winchester If they're not reference cards, you can't get full cover blocks for them, you would need GPU only blocks with some RAM heatsinks
30 Dec 2011 at 14:45 #4 dwskillz dwskillz Associate Joined 27 Feb 2010 Posts 315 reference only ones http://www.overclockers.co.uk/showproduct.php?prodid=WC-067-XS&groupid=962&catid=1520&subcat=
30 Dec 2011 at 15:17 #5 lackofskill lackofskill Associate OP Joined 1 Oct 2010 Posts 97 im not sure if its a reference card how do i find out ?
30 Dec 2011 at 15:20 #6 lackofskill lackofskill Associate OP Joined 1 Oct 2010 Posts 97 this is what i have http://www.overclockers.co.uk/showproduct.php?prodid=GX-128-MS&groupid=701&catid=56&subcat=1752
30 Dec 2011 at 15:40 #7 95thrifles 95thrifles Permabanned Joined 15 Nov 2008 Posts 6,968 Use the link Cleecoo provided, which will tell you you cant have fullcover, as above youll need a universal block and Heatsinks for the VRAM
30 Dec 2011 at 16:18 #8 ThePengu1n ThePengu1n Associate Joined 24 Aug 2011 Posts 723 Location Nr Winchester It's a custom card so no full cover block However, you can use a universal block and some RAM heatsinks, there is even a thread around here somewhere where someone did just that.
30 Dec 2011 at 19:59 #9 lackofskill lackofskill Associate OP Joined 1 Oct 2010 Posts 97 okay thanks for your help ;p
30 Dec 2011 at 21:29 #10 Staffy50 Staffy50 Associate Joined 2 Jan 2010 Posts 360 I have just done that myself with my non ref 6950's.
30 Dec 2011 at 21:42 #11 skyripper skyripper Associate Joined 19 Jul 2011 Posts 2,370 My VTX 6950 non-ref with universal GPU block Just add your own flavour of ram heatsinks and use a thermal adhesive on them so they dont fall off. (Dont use thermal adhesive on the waterblock!)
