MSI 7970 CF Temp Issues
17 Sep 2008
Today I installed 2 X MSI 7970 Twin Frozr.
According to GPU-Z, one card idles at 60c with 99% GPU Load and the other is 40c with 30% Load ? This doesn't look right.
Any ideas?
nope thats quite high for an idle. Swap the cards over in position on the mobo and see if they stay the same.
If the same card is still hot at idle, you may want to take it apart and add some thermal paste
The problem is ULPS is bugged. I cannot stress how much you want to be on the 13.10 beta driver. Remove 13.4, restart, install 13.10 beta, open regedit and search for "EnableUlps" without quotations, change it from 1 to 0, F3 for next search, change that from 1 to 0, restart = ENJOY
