MSI 980 Ti Lightning Air cooling review by 8Pack
OcUK Staff
20 Feb 2012
John Smiths Stadium
The MSI lightning range of cards has been the most successful overclocking series of cards ever made for benching and gamer's alike.
With this MSI have taken both AMD and Nvidia high end GPU redesigned the PCB and power delivery to produce a true hero product.
The last Lightning series was R290X lightning for me a great product taking all benching WR's from single GPU to quad Crossfire. This being said I was very pleased to learn MSI had designed a 980 Ti lightning and that I would be able to bench test it on air cooling and beyond.
The MSI 980 Ti lighting design is robust to say the least. Both in PCB design and cooling its over engineered so that every ounce of performance can be extracted from the 980 TI GPU.
The PCB is a 10 layer design with full 10 Phase Power supplying the GPU alone. The memory has further 3 phase delivery so as to get as much stable power to the mems as possible and enhance the overclocking potential.
The MSI 980 Ti Lightning has a distinctive Black and yellow triple fan cooler that matches perfectly there own M Power or X power Series of motherboards as well as any other black or black and yellow combination motherboards. The card has a full length black back plate which adds rigidity to the PCB, extra cooling and looks great with the lightning branding visible too. On air 2 way SLI is no issue at all but three and four way may need water as to my eyes the fan blades would hit the card below if not a slightly larger gap than 2 slot was available.
Here we have some pics of this aesthetically great looking card mounted in my test rig ready for testing.
Lets now check out some performance results when overclocked. For these overclocking tests I used MSI afterburner to control the card but added no voltage and used the auto fan profile so as the results I achieve can be attained by all most end users dependent on sample quality of course.
Test Rig:
5960X 4875mhz
ASUS RVE X99 motherboard
Kingston DDR4 Predators
8Pack 2000w PSU
Kingston SSD
Windows 8.1 64 Bit
Nvidia Forceware 353.06 Drivers.
3D mark Firestrike
3D Mark Firestrike Xtreme
3D Mark Firestrike Ultra
Heaven 1080P (maxed out)
Valley 1080p Extreme HD
Valley 4K Extreme HD
As you can see from the benchmarks the overclocking performance of this Ti is very high with 1525-1550 mhz core and 2125-2150+ mhz mems no problem on the stock cooler. This is infact the best performing 980 Ti I have ever tested on stock volts and cooling which is very impressive given I have already reviewed many of the flagship cards from all the major players.
Check out our OCUK forum Firestrike thread and you will see this card with a touch of volts beating all water cooled Titan X never mind Ti giving you a measure of how good this Ti really is.
The cooler is both quiet in operation and effective in cooling this overclocked Ti. My sample never got above 68C when being bench tested for a long period of time at high mhz and if for benching you force the fan to full it never exceeds 63C running full pelt!!
In conclusion I recommend this TI to all gamers and overclockers. It is a cool, quiet,well built, performance monster!! and the best I have tested to date.
I will add some LN2 testing results to this review in time. Some world records on the way I think ;)
Hi there
A truly epic card and it is currently on THIS WEEK ONLY at just £599.99, grab one now:
MSI GeForce GTX 980Ti Lightning 6144MB GDDR5 PCI-Express Graphics Card (GTX 980Ti LIGHTNING) @ £599.99 inc VAT
The Lightning is amongst the best of the 980Ti's if not the very best, even our own 8 Pack had some input on the design of this legendary card with boost clocks out of the box close to 1500MHz possible and when overclocked around 1600MHz is possible (not guaranteed).
Ti. The most powerful two letters in the world of GPUs. When paired with our flagship gaming GPU–GeForce GTX 980–it gives you incredible new levels of performance and capabilities. GTX 980 Ti is accelerated by the groundbreaking NVIDIA Maxwell™ architecture to deliver an unbeatable 4K and virtual reality experience. With 2816 NVIDIA® CUDA® cores and 6 GB of memory, it has the horsepower to drive whatever comes next.
Features:
- Twin BIOS
- Enhanced Power Design: 12 GPU Phases, 3 Memory Phases & 10 layer PCB
- SuperPipe Technology: Three 8mm SuperPipes
- Triple Overvoltage
- Triple Temp Monitor
- V-Check Points
- Military Class components
- VR Ready
- DirectX 12 Ready
- 4k Ready
- 6144MB VRAM
Specification
- GeForce 980Ti
- GPU: GeForce 980Ti
- Core Base Clock: 1203MHz
- Core Boost Clock: 1304MHz
- Memory Clock: 7100MHz
- Memory Size: 6144MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2816
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin & 1x 6-Pin
- 600W Gold PSU Required
- 250W-300W TDP
- Dimensions: L=330mm, W=140mm, H=53mm
- Warranty: 3yr
Was [£629.99] Inc. VAT
Only £599.99 inc VAT.
ORDER NOW
Would love this card in a red and black theme (to match my rig) I've been toying with getting it and taking the cover off to spray paint it but I'd be scared of ruining the warranty :/ Seriously good card though. A Titan/FuryX killer for sure
For these reviews do you just take a box off the shelf or do you use a special one that overclocks well?
Try plastidip as it can be peeled off. I've just bought some for spraying a backplate.
MSI give me a credit note, then I remove the item(s) from stock and give to 8 Pack. So it is just from our warehouse, no cherry picking.
Just like with TeamGroup 3866MHz memory review, customers are actually getting better clocks than 8 Pack did, simply because no cherry picking is done so the customer might receive worse or better clocking product.
Are you sure the low temps are nothing to do with the extra cooling fan on the window ledge!! lol
Looks like a great card but so many other things to buy before something like that.
do you rate this card better than your own KFA 980ti on performance at stock speeds?
just curious to how they compare at stock benchmarks!
^^ Very similar at stock. If your in the market for Ti choose the one you most like the look of that compliments your system.
on stock i got
16393 points on firestrike with my KFA 980Ti
would this be classed as a good score with no overclock?
i am happy with how it runs currently
and have never tried to overclock a gcard before i may give it a shot
this weekend and see what improvments i gain.
Firestrike is not just about the Graphics Card. Its alos about the CPU for both the Physics test and Combined tests. Higher CPU high Overall score.
Why I'm under impression that all these 980Ti cards are all the same in terms of OC?
Hard wall 1550MHz. Done. Adding volts can even hurt. So weird architecture.
Good review tho ;)
Maxwell is often like that. The Lightning has solid bios and is very efficient clock for clock.
Better cooling helps more than higher voltage.
Good review tho ;)
Even on chilled water very little extra voltage is required, its all about keeping the core nice and cool to retain higher boost clocks for sustained periods/gaming
