MSI AB not applying OC settings when my PC starts, any ideas?
26 Sep 2013
West End, Southampton
Morning all.
As per thread title, its been doing this for the last 2 weeks or so but I've never questioned why really. I've tried reinstalling drivers and MSI AB, but to no avail. When I want to game, I have to "reset" the profile, then apply "profile 1" to re-apply my clocks then go to fan settings and click "custom profile" again. While this isn't to much of an issue, it does make me question why it's doing this all of a sudden.
thx
Did you tick the apply overclock on start up button? I think it has changed for the newer versions over AB, i was confused by it for a little while.
Not too sure about the fan profile though, i don't think that has anything to do with this tickbox.
Happens to me also. Think its the combination of beta 17 and rivatuner 6.0.0 beta 4.
In MSI it will show the OC, but once in game it shows stock clocks in OSD so have to hit the profile button and apply.
Yes I've always had the "apply overclocking at system startup" checked.
No Matt, hadn't. Yes Matt, overdrive in CCC unlocked. Never had this problem previously in any driver/MSI AB version.
Reinstall drivers but don't unlock overdrive this time. Unlocking it in RadeonPro might cause it as well. What happens is afterburner loads first, applies overclock then CCC loads afterwards and applies its stock settings.
