MSI Afterburner 2.2.0 Beta 1 Released
Man of Honour
9 Jan 2007
Metropolis
http://downloads.guru3d.com/-MSI-Afterburner-2.2.0-Beta-1-download-2604.html
Changes:
- Added core voltage control for reference desing AMD RADEON 6990 graphics cards with VT1556 voltage regulators
- Added core, memory and auxiliary PEXVDD voltage control for custom design MSI N560GTX-Ti Hawk series graphics cards with uP6218+uP6262 voltage regulators
- MSI On-Screen Display server has been upgraded to version 4.2.0. New version gives you the following improvements:
- Added audio capture support to video capture engine. The engine supports stereo audio capture under Windows XP and both multichannel or downmixed stereo capture under Windows Vista and newer operating systems
- High-performance primary desktop video capture support for Windows XP and newer operating systems. Please take a note that currently desktop video capture is not supported under Windows Vista and newer operating systems with Aero Glass interface is enabled, please select classic interface to get it working if necessary (Aero Glass interface is now being automatically disabled by server when desktop screen capture is started and restored after finishing the capture.)
- Updated profiles list
- Changed current value and time rendering Z-order in hardware monitoring graphs renderer
- Added Simplified Chinese localization
God i'm retarded... just found it now, didn't even realise you could go more right on the top tabs, what a noob lol.
How's the sound working with the new version? Looks like I could get rid of FRAPS for this if the quality is good enough.
Uh I never had any problems like that, anyway I played for about an hour and a half and it worked very well, sound can be recorded multichannel or stereo.
The video quality can be tweaked far more than fraps allows, it is pretty damn good I would say.
I'm liking the video capture AND more importantly has stopped crashing BFBC2 with punkbuster. YAY
One small issue. Had to set memory clocks to 1399MHz because anything 1400 or over sets the overclock back to stock :confused:
sorry, i know i aksed this before but cant find the thread anymore. what do i need to change in the config file again?
EDIT : saw it on the download site, sorry.
I am so impressed with this program!, Just an awesome app that once set up you can just forget about under or overclocking the card, when starting aps or games. :-)
I'd say this is on par with FRAPS quality but with way more stuff you can customize, it's amazing and I think i'll be using this over FRAPS more.
This is awesome for recording BC2 for me. I'm not joking when I say I get zero lag recording half size @ 30fps onto an external H/D! Problem is - My whole computer freezes up and I have to do a hard reboot. :( (after about 10 mins of recording)
I'm guessing this is what people are on about when they say they get lock ups with MSI conflicting with punkbuster? Does anyone have a solution? I bought Playclaw few months back but haven't got round to getting a seperate H/D to record on - this MSI afterburner is ace so I won't be using playclaw again (unless I can't fix the freezing problem)
On a side note - my GPU is a 6850 and it's not even overclocked - temps are at about 60 degrees in BC2.
I couldnt get the video capture on 2.1 official to work :(
I'll try classic interface and see if it works.
Nice, it works now, better than fraps :)
