MSI Afterburner 2.2.2 (2012-06-20)
Caporegime
8 Sep 2006
On Ocuk
• Increased upper allowed power limit for power limit adjustment slider on some extreme editions of NVIDIA GeForce GTX 600 series graphics cards
• ATIPDLXX.DLL is no longer included in MSI Afterburner distributive
• MSI On-Screen Display server has been upgraded to version 4.3.4. New version gives you the following improvements:
o Fixed framerate calculation for DirectX10/DirectX11 applications, which actively use presentation testing during rendering (e.g. Max Payne 3)
http://downloads.guru3d.com/Afterburner-2.2.2-download-2562.html
i can only clock my second gpu when its active, so i have to tab out the game to oc. otherwise i cannot move the values....any fix?
In settings tick the box to synchronize settings for similar graphics processors, then both cards will run at the oc you set.
thanks for the response but i already had that box ticked and it doesnt work, it seems like the only way to clock it is when gpu2 is active.
