MSI AfterBurner And CCC Power Control
Caporegime
12 Jul 2007
United Kingdom
As soon as i apply an overclock to afterburner the power control in ccc resets to 0% from +20.
Any idea how i can get round this? Is there anyway to disable power control?
Otherwise im limited to using ccc and its paltry overclock limits. If i remove ccc how will i increase the power control?
Yes:
http://www.techimo.com/forum/graphi...9-enable-higher-overclocks-ccc-reg-entry.html
A simple reg entry to increase CCC limits.
Remember to back up the entry first, keep the moded reg entry handy as most driver updates remove the higher limits.
save below to notepad(remember to save as .reg):
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0000]
"PP_PhmSoftPowerPlayTable"=hex:6f,01,05,01,00,04,04,10,18,58,00,68,00,b8,00,e8,\
03,e8,03,58,00,00,80,01,00,0f,00,00,02,08,3c,00,00,68,00,b8,00,00,18,01,09,\
00,18,01,26,01,83,01,00,00,a0,0c,00,00,30,01,40,01,4b,01,00,00,00,00,00,00,\
aa,00,00,00,78,00,00,00,60,ea,00,00,56,01,0a,00,00,00,14,00,00,00,00,00,00,\
00,01,01,02,03,02,02,02,04,03,02,02,04,80,38,01,48,e8,01,01,ff,7e,04,00,00,\
01,00,00,00,a8,61,00,98,3a,00,84,03,b6,03,00,00,01,00,00,00,50,c3,00,48,e8,\
01,e8,03,7e,04,00,00,01,00,00,00,80,38,01,48,e8,01,01,ff,7e,04,00,00,01,00,\
00,00,34,1b,01,48,e8,01,01,ff,7e,04,00,00,01,00,00,00,08,00,00,00,78,00,00,\
00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,05,00,00,00,78,00,00,00,\
00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,04,00,00,7a,00,00,00,00,\
00,00,f0,d2,00,00,40,9c,00,00,00,00,00,00,00,00,00,00,00,7a,00,00,00,00,04,\
00,70,11,01,00,c0,da,00,00,00,00,00,00,00,01,06,94,11,c4,22,54,24,60,09,3c,\
0f,88,13,0a,00,d0,78,02,00,90,d0,03,00,03,40,9c,00,84,03,50,c3,00,e8,03,68,\
3c,01,01,ff,02,98,3a,00,b6,03,48,e8,01,7e,04,02,98,3a,00,84,03,48,e8,01,e8,\
03,04,84,03,11,00,00,00,e8,03,1a,00,00,00,4b,04,28,00,00,00,4c,04,28,00,00,\
00
No problem.
If anybody's using CrossFire you need to make 2 reg entries and change this:
To this:
'[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0001]'
