MSI AfterBurner Issue
28 Jan 2011
Hey guys,
I formatted my SSD with W10. Now in AF I'm having an issue,
Base clock : 139
Boost clock : 405
When I go in game this rises as normal and peaks at what the Base / Boost was showing before with no loss of FPS or such?
Why is this showing only that? The only thing is (which I don't know if positive) is that the "idle" temp is lower because its running at a slower clock, is this a good thing?
cheers guys.
You need to provide more info like what version of AF you are using etc.
Download latest GPU-Z and what does that say ?
I'm using the latest version. the weirdest thing happened, after installing and opening GPU-Z, AfterBurner is now showing the base and boost back to what it was at before,
Base : 1506
Boost : 4006
and that's what GPU-Z was registering before the change too.
