MSI afterburner keeps crashing
3 Aug 2014
Slamannan Falkirk
MSI afterburner keeps crashing since I installed dirt 3!!
Hi all MSI afterburner keeps crashing on my pc. this has only started from yesterday since I installed dirt3.
Ive uninstalled afterburner and downloaded the latest version but it will run for an hour then will close giving me an error.
so still having the same problems... my pc was running like cr@p I done a fresh install and had it running sweet then I installed dirt 3 again... and it started all over!! I was able to do a system restore and its now running sweet again.
so 2 fresh installs later and a few different versions tried its still playing funny buggers with me... just downloaded PrecisionX so off to give that a try. I did install asus gpu tweak but didint like it
so I tried msi AB again but without monitoring and all seemed good. so ive turned monitoring back on but ive uninstalled asus Ai suite so will report back..
ps.. yea I know no one has bothered to answer me on this thread but ill update it for future searches if anyone has same problem.
wee update... once I had the monitoring turned on for the gpu temp it closed after an hour as it has been doing. no warnings it just freezes then when you try to open A/B it wont open..
again ive turned the monitoring off and its been fine for the last 2 hours.
