MSI Afterburner not allowing memory overclock
26 Oct 2013
Leicester
Hi all
I am trying to overclock my memory on GPU in sig - MSI 980Ti Gaming
I am using afterburner on 388.43 and upping the memory overclock and hitting apply does not seem to do anything. Have restarted multiple times to no avail. Any ideas?
Same here with my 970 almost. I can change the clock but not while there's any load on the gpu. Ie, can't do it while gaming or mining, but can do it when idling on the desktop.
No such issues here with a 970 on Afterburner 4.4.0.11945 and Nvidia 388.59.
The MSI Gaming App... hopefully it's not installed and activated?
Few weeks ago I had a bit of trouble when trying to update Afterburner and Rivatuner. Some things were messed up (in my case the fan control kept going back to default, and Rivatuner would display 0MB memory usage). So I uninstalled both completely, then installed the latest, and all good. Worth a try if you haven't tried yet.
I believe some, not all, of these issues are caused by Windows updates.
