MSI Afterburner overlay won't work.
10 Apr 2012
I'm trying to use the MSI Afterburner overlay to monitor fps as its very small and unintrusive after a tiny bit of customization, yet I cannot get it to work at all in any game, I've set the shortcuts to F2 = show F3 = toggle F4 = hide. Yet pressing them does nothing, I've looked through all the options and everything's ticked, even have the MSI Server thing with the games I'm trying to show fps in as application profiles. I don't really wanna use Dxtory to monitor fps because the fps number is too large imo, yet this seems impossible, but I've seen tons of people monitor with AB...
Help! :(
I don't use anything on any of my games anymore, no post-processing except in Street Fighter 4, which is a core feature, and I don't think it works the same.
Okay I sort of got it working, but it's only showing my GPU Temp, not my Framerate despite the fact that framerate is ticked. Wtf...
Does this help? you have to set each thing you want to show in the OSD. Just turning it on/off wont display.
If you have set framerate to show in OSD then I have no idea sorry.
Yes! I got it man, I didn't realise you had to configure each settings properties manually, it works now :) thanks!
One last little problem: It says D3D9 : 60 FPS in the corner, that's kind of okay but is there a way to make it show purely just a number? It's way too intrusive with all that garbage up there, I was really spoilt by the ENB's framerate display, wanna get it again without an ENB and with all games. :p
