Msi Afterburner problem
11 Jul 2003
Telford//west mids
I clocked my Msi 3080 suprime x a tad and this is how it shows,gpuz shows it correct but afterburner does not is there any reason for this.
Thanks.
download hwinfo and see what it says, should give you the correct readout. Afterburner is what most people go by though...
Thanks.
Use the curve if you want to extend boost clock or have it run at top boost when needed plus will be lower temp and voltage than just using +core
