I used this to clock my 4870 to 650/1300/1700
I used the stock fan profile, i noticed though that the fan kicks in really hard and loud sometimes, i checked the temps and they were like 90C which seems pretty hot, i think the fan runs normally at a very low level and then comes in really loud when the card gets hot
If i turn the fan control to manual, i can set a much higher fan speed, for normal operation, and this should keep the card running cooler, so i dont get this fan on fan off of the auto setup
My old GTX 280 was also OC and i had the fan on 75%, this kept the card cool and was not to noisy
The OC on my 4870 is quite conservative so would 65% on the fan on manual be enough to keep it cool?
Also if the card does hot up, will the fan speed go up in manual mode or it stay set at whatever % you put in regardless of how hot the card gets?
I'd like to set it at a level, that keeps it cool, and is not to noisy, the auto setup as per above seems to either be off or very low and then kicks in with an almight bang which is quite annoying really
