- 30 Mar 2019
Hi all,
I have an issue with games crashing a lot, after checking after burner logs I see cpu usage doesn't go above 70% and a similar situation for RAM. On GPU it's maxing out a lot with gpu clock raising with demand all beit not to its full potential, but the memory clock is only raising from its idle 300 to 540 :/ the bar is set to 1750 or 1250 or what ever it should be, gpu and memory clocks I forget which one
What's weird is bearing in mind I have a phenom ii 965... my cpu should be bottlenecking the gpu not the other way round. And my RAM is only 8GB 1333 Mhz Ddr3. The gpu should be handling everything they throw at it right?
Is there any way to force gpu and memory clock to go to maximum during full screen applications?
I checked settings and doesn't seem to be an option
Anyone know a fix? Pwease
