MSI B350M Whea Errors
5 Feb 2012
I've had 5068 WHEA error in the past 24 hours on MSI's beta bios for gen 3.
I have a 3600 and a 5700, A lot of the whea error ids lead to "AMD USB3.1 eXtensible Host Controller drivers / Micro-Star MS-7A34"
PCIE Asus WIFI Card failures
Among other random ID's.
Am going to assume that this is due to msis beta and being forced to use it if I want gen 3 support. But I end up getting a entire system shutdown when I touch anything remotely 3D. Like Games, Videos etc, Sometimes a game will run flawlessly other times I'll boot a game up and it will die.
Mutiable OS reinstalls with no fixes too...
Doing SFC after installing windows 10 gives:
Windows Resource Protection found corrupt files but was unable to fix some of them. For online repairs, details are included in the CBS log file located at windir\Logs\CBS\CBS.log. For example C:\Windows\Logs\CBS\CBS.log. For offline repairs, details are included in the log file provided by the /OFFLOGFILE flag.
However I've tripled checked both ssds and there both completely fine too.
Going to loose my mind over this ryzen/navi release @.@
Does your motherboard support 3600? Because the latest bios found is from 28/01/2019, having no BIOS supporting Ryzen 3000.
https://www.msi.com/Motherboard/support/B350M-GAMING-PRO.html
I don't own the gaming pro I own the b350m mortar which does have a bios for the 3rd gen though as stated by msi it's a "beta" bios
You wrote B350M and when used google got me that.
MSI says that there is a proper bios out next week
https://www.msi.com/blog/the-latest-bios-for-amd-300-400-series-motherboard
Maybe raise your issue there, there are moderators from MSI replying to people.
Also on Asrock (i know different but), states to remove the AMD Unified drivers in safe mode.
(use also DDU).
Then log in normal mode, install the latest drivers, then reflash the BIOS.
It's just normal you need to wait for fixes, I've not chcked to see if I am getting any errors yet will do tonight.
