- 11 Dec 2005
- Cheshire
MSI are running a unique promotion where if you purchase any award winning MSI Z87 OC Motherboard, you are entitled to a FREE copy of Call Of Duty: Ghosts worth over £39!
Simply email your proof of purchase to MSI with a copy of your motherboards serial number within 7 days of purchase to be entitled. Easy!
CLICK HERE
MSI Z87 Mpower SP Intel Z87 (Socket 1150) DDR3 ATX Motherboard @ £149.99 inc VAT
Z87 MPOWER SP OVERVIEW
OC CERTIFIED
OC Certified is a military class burn-in test for motherboards. Running Prime95 for over 24 hours with a highly overclocked CPU is already a stressing endeavor, but removing all airflow from the motherboard ensures that only the best motherboards survive. If a motherboard can survive this, it can survive any overclocking situation.
OC ESSENTIALS
A small set of tools that are essential to get the best performance out of your motherboard. These features increase stability, assist in trouble shooting, allow you to keep your complete system in check and allow for simple management. This way you can keep your mind on overclocking.
MILITARY CLASS 4 COMPONENTS
Military Class 4 is the next step in high quality components. The Hi-c CAPs, Super Ferrite Chokes and Dark CAPs will make sure that your PC runs more stable under extreme gaming conditions.
SOUND BLASTER CINEMA
Powered by the SBX Pro Studio technologies, Sound Blaster Cinema enables you to clearly hear specific sounds in gaming environments, making your ears a decisive tool on the battlefield.
KILL YOUR LAG!
The Killer™ E2200 Intelligent Networking Platform is built for maximum networking performance for online games and high-quality streaming media. Featuring Advanced Stream Detect™, Killer E2200 automatically detects and accelerates game traffic ahead of other network traffic for smoother, stutter-free in-game performance and the competitive edge.
AUDIO BOOST
Because the complete audio circuitry is isolated from other features, you'll enjoy less interference and more stability. The built-in headphone amplifier allows you to use studio-grade headgear and get the most amazing sound quality out of your gaming PC.
OC GENIE 4
OC Genie is the world's first built-in hardware overclocking technology on motherboards. With this new generation of OC Genie, we're giving you even more performance. The OC Genie button works as you expect it to, but now you have even more control.
Super RAID
MSI's exclusive Super RAID application helps to easily setup and configure to boost your system performance and stay current with automatic, no-wait updates to your e-mail, social networks, news, and more.
World's 1st PCI Express Gen 3 Motherboard Brand
With ultra-high 32GB/s transfer bandwidth, PCI Express Gen 3 provides a 2X faster transfer rate than the previous generation, this delivers amazing capabilities for true next generation extreme gaming.
3 Display Outputs
With the 4th Gen Intel® Core processors featuring Intel® HD Graphics core inside, MSI's 8 series motherboards that equip with 3 video ports support the triple display outputs a more flexible usage.
4K UHD Support
Enjoy the awesome 4K UHD video playback now! MSI's 8 series motherboards that equip with HDMI port(s) supports the latest and the most innovative 4K UHD (2160p ultra-high definition) signal outputs to provide an unprecedented visual experience.
- Supports 4th Gen Intel® Core™ / Pentium® / Celeron® processors for LGA 1150 socket
- Supports DDR3-3000(OC) Memory
- Supports USB 3.0 + SATA 6Gb/s
- 16 Phase DigitALL Power Design
- Multi-GPU: NVIDIA SLI & AMD CrossFire Support
- OC Certified: Military Class Burn-in Test Passed
- Military Class 4: Top Quality & Stability
- OC Genie 4: Overclock in 1 Second
- Click BIOS 4: Easily Fine-tune Your System
- PCI Express Gen 3: World's 1st PCI Express Gen 3 Motherboard Brand
- Audio Boost: Reward Your Ears with True Quality
- Killer Ethernet: Kill Your Lag
- Sound Blaster Cinema: Realistic Surround Sound Experience
Specifications
Form Factor:
ATX - 30.5cm x 24.4cm
CPU Socket:
1150
Graphics Interface:
PCI-e x16 GEN 3.0
CrossFire:
Yes
SLI:
Yes
RAID:
0/1/5/10
Memory Type:
DDR3
Memory Speed (Mhz):
1066/1333/1600/1866/2000/2133/2200/2400/2600*/2666*/2800*/3000* (*Overclocked)
Memory Channel:
Dual
Memory Capacity:
64GB
Back Panel I/O:
1x PS/2 Keyboard & Mouse Combo, 1x 10/100/1000 (LAN), 6x USB 3.0, 2x USB 2.0, 1x DisplayPort, 2x HDMI, 1x 7.1 HD Audio, 1x Optical SPDIF, 1x Clear CMOS Button
Internal I/O:
ATX 24-Pin power connector, 8-pin ATX 12V power connector, 2x 4-pin CPU fan connectors, 3x 4-pin System fan connectors, 8x SATA 6Gb/s connectors, 3x USB 2.0 connectors (supports additional 6 USB 2.0 ports), 1x USB 3.0 connector (supports additional 2 USB 3.0 ports), 1x Discharge jumper, 1x Multi BIOS Switch, 1x Trusted Platform Module (TPM) header, 1x Front Panel Audio connector, 2x System panel connectors, 1x Chassis Intrusion connector, 14x V-Check points (7x V-Check connectors, 7x V-Check spots), 1x GO2BIOS button, 1x OC Genie button, 1x Reset button, 1x Power button, 2x Base Clock control buttons, 1x Clear CMOS jumper, 1x OC switch, 1x 2-Digit Debug Code LED
Expansion:
3x PCI-e 3.0 x16 (Bandwidth at x16 single mode, x8/x8 dual mode, x8/x4/x4 triple mode), 4x PCI-e x1
Only £149.99 inc VAT.
ORDER NOW
CLICK HERE
OC CERTIFIED
OC ESSENTIALS
KILL YOUR LAG!
AUDIO BOOST
OC GENIE 4
Super RAID
3 Display Outputs
4K UHD Support
Specifications
Form Factor:
CPU Socket:
1150
Graphics Interface:
PCI-e x16 GEN 3.0
CrossFire:
Yes
SLI:
Yes
RAID:
0/1/5/10
Memory Type:
DDR3
Memory Speed (Mhz):
Memory Channel:
Dual
Memory Capacity:
64GB
Back Panel I/O:
Internal I/O:
Expansion:
ORDER NOW
