MSI Fan Control?
Man of Honour
17 Oct 2002
Hi guys,
My Asus P8P67 Pro controls the fan speed of two case fans - ie, I can select speed profiles in the BIOS to slow them down.
Can the MSI equivilent do this?
Considering a Z68 board, and after the randomness of Asus, I think MSI migth be the way forward.
Yes, I have the MSI P67A-C45 and I can allocate a fixed percentage of the case fan's speed in the BIOS - for example i am running my case fans at 75% (i think there are options of 25, 50, 75 or 100%).
The CPU fan controller has the option of running at a set percentage of its total fan speed but will increase if it goes over a set temperature. e.g. i have mine set at 50% and will kick in to full speed if my temps go over 50degrees.
