Hiya's
I have been a PC gamer for many years but I am very new to the world of overclocking, So when it came to building a new system I went for the MSI Fusion motherboard as it looked the most user friendly with the overclocking features as it manages it all for you
and I also bought the Gigabyte GTX460 OC, the Phenom II Quad Core processor with the Arctic Freezer 13 cooler, but I am experiencing problems
in normal mode everything is fine, but when I go into overclock mode the CPU temperature goes right up and if I play a game for a little while the computer will switch off. I am only presuming the cooler isnt dissipating the heat properley ? The cooler isnt actually mounted ideally as the cooler only mounts one of 2 ways round, either to point towards the PSU or if I mounted it the other way the cooler fan would be VERY close to the PSU fan if it will fit that way at all, it would have been better if the cooler mounted 90 degrees around, this way the fan would blow straight towards the case extraction fan. (I dont think I can post pictures on here to show you) I cant see the problem being caused by a lack of case fans as I have 2x 80mm fans sucking in from the front of tower, an 80mm fan in the side of the case above the cpu cooler, a 120mm fan blowing out the back of the case and the OCZ ModXstream-pro also has a big fan just above the CPU cooler. Am not really sure which direction to go in, so any help you guys can give me would be very much appreciated
Thankyouuuuuu
Thankyouuuuuu
