25 Apr 2013 at 22:16 #1 DanzP DanzP Associate Joined 13 Jul 2010 Posts 64 Location Nottingham OK so my laptop is an MSI GE60 0ND It has the Killer E2200 Card in it Has the latest drivers but on my 100MB Connection im getting around 40MB On another laptop i get the 105MB speeds (wired on both) Any ideas? Last edited: 25 Apr 2013
26 Apr 2013 at 00:07 #2 bremen1874 bremen1874 Soldato Joined 20 Oct 2008 Posts 12,083 Temporarily disable any anti-virus and firewall software and see if that changes anything. If it was a desktop and a discrete card I'd suggest binning the Killer completely, but with a laptop you're stuck with it. P.S. If you mean Megabits then it's Mb (or Mbit) not MB (which refers to Megabytes).
26 Apr 2013 at 00:56 #3 DanzP DanzP Associate OP Joined 13 Jul 2010 Posts 64 Location Nottingham Yeah sorry its Mb Disabled all AV / FW and still the same the Killer Network manager says the card is running in 1000Mb so does windows network status i really am stumped
26 Apr 2013 at 09:20 #5 KIA KIA Man of Honour Joined 14 Nov 2004 Posts 13,888 Same speed when you transfer across LAN? Did you install the software boat? Sometimes it comes with QoS features.
26 Apr 2013 at 10:45 #6 DanzP DanzP Associate OP Joined 13 Jul 2010 Posts 64 Location Nottingham I have an SSD and a 7200rpm HHD so i dont think its bottlenecking Im not sure about the LAN as its only ps3 and cbox wired to it The other laptop in the house when wired to the same ethernet cable im using got full speed
