hi I am considering changing the thermal paste on my msi GeForce 680, is the paste already on a good make or would you recommend replacing it, in the past the manufactures tend to use poor quality paste, I have a tiny bit of ic diamond 24 and some prolima tech pk-3, my temps are about 80 deg running splintercell blacklist on ultra settings... which would you recommend thanks...
PK3 is the best paste i have used, knocked 9 degrees off a mates 7870 tahiti LE
