- 6 Apr 2018
Hi All,
Looking for some guidance and/or help with something on the MSI GP63 which i got from overclockers.co.uk 3 years ago and it has served me very very well and still going solid thankfully, but. The ram on the machine is being eaten alive (5gb of it) is being reserved for the onboard integrated gpu, it has a GTX 1060 so the onboard isn't needed and went to disable/remove it but found i couldn't locate the advanced chipset option in the bios and disabling the iGPU doesn't clear the ram and uninstalling it the damn iGPU is back on reboot (thanks windows 11 i guess).
While its not the end of the world its driving me crazy as machine only has 16 gig of ram to start with where its down to 15.8gb for what ever reason and then 5gb on near clean boot still being used
Regards
Steo
Regards
Steo
