MSI GS70 2OD-STEALTH
Could be the Windows 8 key is embedded into the BIOS and would cause complications ie not being able to reinstall Windows 8 using a DVD as the original is OEM.
Had a similar problem with my G46VW, had to hunt the internet for a OEM ISO to reinstall.
I'm thinking about getting the MSI GS702OD-409UK STEALTH but it also has the same thing in the description which is putting me off.
I'd be wanting to upgrade the boot drive and do a fresh install.
Has anyone got any more info on this?
Sorry I ended up buying an P35K over the MSI, so cant really comment on the internals. No problems installing W7, but just make sure you've downloaded all the drivers from MSI prior to wiping the old system.
Fish
The MSI's don't (actually that's a lie there is a drivers cd IIRC, which I found funny considering the lack of optical drive :D but no full recovery media) but they do come with software to create your recovery media, I just bought a cheap 32gb flash drive and used that it needs 18gb IIRC.
