- 19 Feb 2014
I just got myself a new laptop thought I had made a great choice but seriously beginning to doubt in my choice. Been using it a couple of days now put some games on had a little problem with gta v while I was playing my ram filled right and caused system to lock up so i thought i would just update gpu drivers.
But no mater what they don't work. Done all the work around like selecting gtx 970 in global setting and also adding game exe to nvcp. None worked always used Intel gpu.
So after a bit more looking around it seams you can only use Msi oem gpu drivers as nvidia does not support hybrid power that is on Msi laptops.
So how are you ment to update your gpu drivers when games Come out.if it's a case of waiting for Msi to do it I think hell would freeze over before the bring out new drivers the current one for mine is 353.74. Nvidia is up to 358.50
Feeling really annoyed
