Hi everyone. Hope this is the correct place to post this.
I recently purchased this MSI laptop from OCUK and have noticed some issues with the monitor. Aside from the fact that the website says it has a 4k 120hz IPS panel but appears to be locked at 60hz, It looks like there is a pressure point in the bottom right corner of the monitor which doesn't seem right.
I've never had a 4k monitor before, or a laptop this thin and I was wondering if anyone else who has the same laptop or one with similar specs would be able to shed some light on whether or not this is normal before I go off and make a complaint.
Here is an image of the monitor on whilst watching Netflix during a black screen. The colours on the screen are exaggerated because I had to drop the shutter speed on my phone to get a good picture, but notice the brightness along the bottom right edge of the monitor, where it looks like something is pushing against the panel almost as if the frame is too tight and distorting the screen.
What do you think? Am I going crazy or do I have a faulty panel?
, so i had to source a new lid and transfer the screen and bezel , the bezel has a row of clips on the bottom and an adhesive strip that causes the distortion you can see , some are better than others but the long and short of it is that its just poor engineering , designed for cheapness and aesthetics.
