- 30 Jan 2016
Hi guys, I received my msi gtx1080ti founders edition this morning. As you'd expect I was super exited to get it installed and try the beast out. What a beast it is, great performance, hitting around 120fps with everything maxed out at 1440p however the temps seem a little concerning at least to me.
My old Zotac gtx970 had two fans so it was pretty quiet and efficient at cooling. This is my first time owning a founders card or reference design if you prefer and using a gpu with a blower.
The temps when Idle for the 1080ti are around 33-36c and as soon as I start a game up it goes to 82c and pretty much stays around those temps. Also noisy than expected.
Is it normal to be at that temp or should it be lower? I'll list other specs of my rig for reference:
Fractal r5 case
intel i76700k at stock
x2 be quiet silent wings 3 (140mm) high speed fans (one in the front, one in the back)
be quiet dark power pro 750w psu
16gb ddr4 ram
akasa venom voodoo cpu cooler
As great as the card is performance wise I feel a little let down by the noise and high temps. Kinda thinking I should have waited to get aftermarket version like the evga ftw edition. I could return it but I'm conflicted on whether to put up with the noise and temps or send it back and wait for the other versions to come out.
Fractal r5 case
16gb ddr4 ram
