MSI GTX 670 PE OC
25 May 2013
Kent.
This card is great at the moment and probably will be for years to come, I just want to squeeze a bit more juice from it, I tried it before but Unique Valley crashed upon a light OC. Would it be wise to up it a little on Mem and Core or just leave it stock Preclocked?
Cheers.
Work on the core first, 10mhz at a time. Find your optimal boost core clock. If you get driver errors back down to the last known stable clock. Then work on the memory, 50mhz at a time, when you see artifacts in testing, once again back off. Set power target in afterburner to max%. Test with the heaven 4.0 bench, it's a good quick stability test for gpu clocking, but the best test of all is the games you play most.
