MSI GTX 680 Lightning
Probably in the next few weeks (places other than Overclockers UK anyway, but they're also damn good at getting things in quick). Hope you get a fantastic SLi setup OP. You will need to wait a little while for some compatible blocks though as the board will be a custom layout. Until then it'd have to be on air.
cheaper to get 2 Asus GeForce GTX 670 DirectCU II TOP probably be very close in OC also they are bringing out a water block for it very soon from what i hear.
The triple overvoltage etc... doesn't mean a thing if you're still limited to 1.175v. I hope they aren't limited but have a hunch they will be.
You'll be waiting a long time if at all to get full cover waterblocks for these, the 7970 lightning blocks aren't even out yet.
The tf4 cooler fitted to these is probably the best gpu air cooler on the market.
At last, a card that does what it says on the tin! 1.3v could be interesting, possibly push past 1400mhz with that.
lightnings i had a 6970 lightning and they never released blocks for them only reason i ditched it tbh but the cooler looks great on them :-)
They may release a waterblock, depends if anyone views it as worth it. The TFIV cooler is brilliant though, quiet and highly effective.
