MSI GTX 780 Ti Lightning Pictured, Overclocked, and Tested
Man of Honour
21 May 2012
Dalek flagship
Ahead of its launch, French tech publication Le Comptoir du Hardware scored an early sample, and wasted no time in taking high-res pictures of the card, its innards, and putting it through a battery of benchmarks. Their first opinion? That EVGA's GTX 780 Ti Classified K|ngp|n has met its match. Taller than most graphics cards, and thicker than two slots, MSI GTX 780 Ti Lightning is based on the same new-generation TriFrozr cooling solution as the GTX 780 Lightning. Its underlying PCB is unchanged, too. The card draws power from a pair of 8-pin PCIe power connectors, and conditions it using a gargantuan 20-phase VRM. The VRM uses two separate controllers for GPU and memory+PLL. The GPU and memory both draw power from the power connectors, while only the PLL draws power from the slot. This way, memory OC isn't held back by the PCIe slot power supply.
The PCB also features consolidated voltage measurement points, independent fan headers for each of the cooler's three fans (letting you control individual fan-speeds), and dual-BIOS. The cooling solution is features multiple aluminium fin stacks that draw heat from a large nickel-plated copper base, using seven 8 mm-thick heat pipes; which are ventilated by a trio of fans. MSI claims that the cooler is capable of handling thermal loads of up to 550W. The "Lightning" logo on the cooler's top lights up to the thermal load the cooler is handling. It's white up to 150W, gets brighter between 150W and 210W, and goes red beyond 210W.
The card ships with out of the box clock speeds of 993 MHz core, 1059 MHz GPU Boost, and 7.00 GHz memory. The reviewer was able to overclock that up to a staggering 1248 MHz core, and 1314 MHz GPU Boost, while leaving the memory untouched; and the memory in a separate attempt up to 8.00 GHz, while leaving the GPU untouched. The card was tested on a system with Core i7-4960X, 16 GB of quad-channel DDR3-2500 MHz memory, and an MSI Big Bang XPower II motherboard. It achieved 3DMark 11 (performance preset) score of P17872 single-handedly.
http://www.techpowerup.com/197149/msi-gtx-780-ti-lightning-pictured-overclocked-and-tested.html
Roll over Beethoven
Looks impressive, although that 3dmark 11 gphx score is low isn't it? for the clocks used?
1325Mhz clocks for that run and 18703 points returned is a good score. If it is capable of running at over 1400Mhz, as shown in the first screenie, then it would easily be hitting 19500 GPU points.
I hope this gets released.
That looks like retail packaging in the pics, I do hope this gets out to give EVGA some competition.
Check out the volts they were using, very low.:D
