i have just purchased a msi gtx 980 gamer gpu whic i am trying to get to work with 2 120hz monitors as it was working fine before with my msi gtx 770 lighting but that card had 2 dvi ports while this new card only has 1 dual link dvi port, my question is can i use a DisplayPort (DP) to DVI cable to connect my second monitor ''resolution 1920x1080, 120hz'' to my graphics card, both my monitors only have 1 dvi output each, i may have to send the card back and get a gigabyte instead as that comes with 2 dvi ports
help is appreciated, thanks in advance
ill just have to hope it works at 120hz
