MSI reference style cards here and no problems with the fans.
....if you look under the Fan Speed (RPM) you will see red blips every thirty seconds or so which shows that both the cooling fans spin up to around 800rpm for a few seconds and then stops. Checking with the case cover off and it confirms the stopping and starting of the fans. This will repeat forever, or so it seems.
This did not happen with the previous 344.16 drivers and going back to them gives me this...
ManuelG said
Let me look into this. I know its not a reference design but could someone share their VBIOS ROM for their MSI GeForce GTX 970 GPU by extracting it using GPU-Z or any other utility and then email it to [email protected]? Include a description of the issue so I know what it is in reference to or simply a link back to this thread. Thanks.
Nice one Vimes, I've made a post on that very thread you just posted, hopefully Nvidia will sort this out with MSI.Maybe with Nvidia picking up on this issue something might be done.....
https://forums.geforce.com/default/...0-fan-problems-with-gtx-980-msi-gaming-help-/
344.60 are just the same and the fans are meant to be at zero until the temp gets to 60c, IIRC
Also sent my BIOS along with details of issue to driverfeedback email address.
Model: MSI GTX 970 Gaming 4G
Manufacturers Code: 912-V316-001
BIOS: NV316MH.126
Just to note this issue does not occur on 344.16 driver.
Problem on driver 344.48 and 344.60
but it does not work as it already detects that my card has BIOS version 126 (updated from 125) and the 180 BIOS is for cards with the Hynix memory and not the Samsung type.This looks to be a VBIOS issue. MSI already has a fixed VBIOS that corrects this problem. Can those with MSI 970/980 cards please check if a new VBIOS is available to you through their Live Update software?
http://download.msi.com/uti_exe/LiveUpdate.zip
If not, please contact MSI and find out if they can provide you with the fixed VBIOS. If they are not aware of this, lmk and I will check with our product manager to see what the status of the VBIOS is. Thanks.
ManuelG:
Thanks. Let me look into this and get back to everyone in this thread.
Enough of flaming on MSI
>>Please read and comply with the Forum Rules.<<
If you have an issue mentioned in this topic with your 970 or 980, RMA it.
If you can't understand that MSI is unable (or was) to reproduce the issue, then we can't do anything about it. Also note that MSI has lots of different things to do, not just fixing 970 fan issue.
Any updates will be posted by Mods/Admins here.
Link >> https://forums.geforce.com/default/topic/786710/geforce-drivers/344-48-and-344-60-fan-problems-with-gtx-980-msi-gaming-help-/4/ManuelG @ Nvidia said:I am sorry this is taking longer. Our software team wants to first take a look at why there is a fan behavior difference between drivers but still confident in a VBIOS update is required.
Everyone here is pretty busy so may take another 24-48 hours before I might have an update to share.
Can you send back and change brands? I would like to do this and go for the gigabyte.
