MSI GX620 Review Thread.
Man of Honour
30 Oct 2003
Essex
I bought a new laptop last week so thought I would give it a little review, after searching on these forums I found a few threads about it including this one http://forums.overclockers.co.uk/showthread.php?t=17917764&highlight=gx620 but no real details.
The Machine
Specifications
Intel®Core2 Duo P8400 2.26GHz
(DDR2 800) 4 GB
15.4" (1680x1050)
nVIDIA Geforce 9600M GT, 512MB DDR3 VRAM
320GB SATA (5400RPM)
DVD Super Multi
2.0M Camera
4-in-1 Card Reader, SD/MMC/MS/MS Pro
Built-in Gigabit Ethernet LAN and Modem Module
Built-in 802.11b/g/n WLAN Card / Bluetooth V2.0+EDR
Graphics Card Output (15-pin, D-Sub) X 1
USB2.0 Port X 2
Mic-in Port X 1
Headphone Output X 1
Modem Port X 1
LAN Port X 1
PCI Express Card X 1
eSATA (USB Combo) X 1
HDMI X 1
90W
9 cell Battery
358(L) X 260(D) X 27~31(H)mm
2.7KG
First Impressions
The machine came well packed with an array of extras opening the box you get a MSI backpack which seems fairly well made in black and metallic red, This was not to my personal taste so was given to a colleague in the office. You get a MSI wired gaming mouse, the mouse is in the style of the logitech G-Series with 5 speed variable track at the touch of a button, the different track speeds are indicated by a change in the colour of the LED in the mouse scroll button. 7 weights are also included to put in the mouse to adjust its weight.
Finally you get the machine and battery, the machine is fairly well built with a brushed aluminium finish over most of it. Red plastic around the edges is very red and feels fairly flimsy in places specifically in the canter above the touch buttons (Ill come onto them later),this could let the machine down in the future but only the test of time will tell.
Let’s move onto the touch buttons, from left to right there are four touch buttons for media, previous track, stop, play/pause and next track all of which work in media player and other apps. There is an eco button which changes the laptops LCD and battery mode for games, cinema, office, projector and battery saving mode.
Now let’s move onto the more interesting button, the “Turbo” button at first was a strange one, it didn’t seem to work, until I plugged the machine in. I should have read the instructions really, anyway this was neither here nor there until I went into the instructions, then onto the MSI website. The best description I could find about this button, taken directly from the MSI Site was this:
“With MSI exclusive Turbo Drive Engine Technology, while the GX620 is in AC mode, just by touching the turbo button above the keyboard, you can simultaneously increase the speed of your CPU, also the computer will run smoother and to the best of its abilities.”
*The test result differs under different testing environment
So that was it, the next thing then was to find out what this button does and try to draw some of my own conclusions. Firstly I took a few cpuid screenshots under basic desktop applications like excel and word. Let’s face it, it’s a simple place to start but with not a lot running what does it do?
Before and after screen shots below:
So the button simply overclocks the FSB from 266 to 308 MHz with a 6 multi, overclocking the cpu under desktop conditions from roughly 1.6 to 1.85GHz, not extreme, but fair play it gives a nice boost when things are getting tough.
Let’s now move onto what this button does when placing both cores under full load with a prime95 small FFT’s stress test.
So what have we got here? A button that on demand overclocks the cpu by 250Mhz under standard desktop conditions, But when things get tough and your either gaming away or maxing the cores out rendering, you get a boost from 2.261 to 2.623GHz. Thats a full 362Mhz overclock along with all the extra memory bandwidth that comes along with it, the extra performance could be the difference of a few frames in some of todays games and that can’t be a bad thing in any laptop.
Finally on the button side of things you’ve got a bluetooth button, a web cam button, wireless button and a programmable button for your favourite apps.
A quick word on the LCD before I go onto benchmarks and alike, the lcd has no dead pixels is crisp and sharp, it scales quite well down resolutions but is noticably blury at lower resolutions. There is a variety of this machine with a 1280x800 screen so there is a choice if you prefer a bigger resolution.
Vista Experience Screenshots
Benchmarks & Gaming Performance
Far Cry 2
Time to see how the GX620 performs at its native resolution of 1680x1050 with the following settings:
Now the DX10 performance, AA performance and performance if I scale down the resolution I am yet to test. I suspect that the DX10 performance of the card won’t be great, I will update later to confirm this but for now I will give you an idea of frames:
Low: 23, Average: 25, high 35
I must say that the above doesn’t sound all that good but after playing for an hour I thought it looked pretty good and played smoothly despite the fps.
CSS
Running CSS at full settings with 2x AA gave pretty good results, on a server with 48 people on maps such as Dust 2, Italy and glass, the machine rarely went lower than 60 fps and generally gave around 80.
Conclusions
I won’t draw a conclusion just yet but let’s say for now that I am suitably impressed with the machine. While typing this however I did find that the keyboard is going to take some getting used to, the ctrl and the function keys at the bottom right of the keyboard are the wrong way around. The “.”, “?” and some other keys are almost half keys, this is to accommodate a number pad to the right of the keyboard but could prove fiddly to hit for touch typists and gamers alike.
My final thought is that if you are looking for a gaming machine at sub £1000 then you can’t go far wrong.
Where did you buy this?
Sorry for bringing this thread back from the dead, but...
Does anyone know where I can buy this spec laptop in the UK? Or a reputable overseas vendor that ships here? I can only find the old spec gx620, and would really like to price the current GX620 as spec'd in this thread.
Any advice would be greatly appreciated!
Lookup the GX725-210UK - expensive but check out the spec, should be getting one in the next week or two hopefully. Typing from a GX700 now :)
Just a little update on the thread, I have sucessfully updated the machine from a p8400 to a p9500 (best processor with the same tdp) however this voided the waranty which is not a problem as my machines are used for business and replaced every 2 years.
More on the build - over a period the machine has been heating up around the right hinge like you wouldn't believe, this has resulted in the hinge breaking the plastic on the front and back bezels therefore causing problems opening and closing the screen.
After taking the machine appart it seems that this is a result of dust build up in the cooling solution. If you are looking at buying a MSI G Series laptop, with the recent new chassis, do keep an eye on the heat and clean out the heat sink on a regular basis. If you do this the heat will not penetrate the plastic causing it to become weak.
Anyway the above is no longer relevant as last week I had another problem when the machine fell 5 feet onto concerete, all the internals survived including the screen incredibly. however the case is now mullered.
A quick call to MSI today and I now have a quote for the following parts:
lcd back bezel: £22.14
lcd front bezel: £4.77
Upper casing : £21.47
total with carage & admin £83.24
They wanted to take the machine back in for repair but when I told them this was simply out of the question due to it being my work daily machine, they agreed to supply just the parts which will be shipped out to me in the week.
For those of you that care, and to prevent you getting passed from pillar to post, the best number for msi notebook support UK is
0031402676141
Overall having owned almost all brands of laptop and having owned many that have had build issues straight from the factory (check asus "F3 series palmrest crack"), I would say that I am subtibly impressed with MSI.
For information the asus of mine showed a fault after just 6 weeks, asus were particulary unhelpfull and even worse couldn't supply spare parts to the uk (only North America). As I was using this daily, loosing it for a day would have cost me more than the total value of the machine, so out with the old in with the new.
Overall I found the support from the msi uk support guys (who are in the Netherlands) pretty good and the prices supprisingly reasonable.
I managed to get the last one at a popular online retailer. the supply into the UK seems pretty limited so it makes the machines quite rare.
I thought they were winding me up when they said the guys name was Fred, either that or I thought Fred was just a random name that was used when people didn't want to give a name.
But yes I spoke to Fred who is on the case sorting it out with your factory to make me happy again. :D
It seems that its often the case in large orginasations, illogical but hey ho!
Anyway I have been in contact with MSI again today and things seem to be ticking along nicely, they are sending out a set of screen rubbers of which I was offered different colours etc. I opted for the straight black rubbers as a direct replacement, free of charge! (like the feet these need some proper glue for any kind of longevity).
The rest of the chassis is currently flowing through the system, we have received an invoice and have raised a payment for this. As soon as the payment has cleared with MSI they will ship the parts.
I must say really solid performance here from MSI, straight talking advice and no messing around. I should have my bits some time next week which will be great.
Now I just wonder if I should ring and enquire about colour on the replacement parts a gx with the blue or silver trim provided to the US would really make my day.
Either way one happy man here! congrats for the good customer service MSI.
Another +1 here for MSI and good customer support. I repasted the heatsink in my GX700 laptop and one of the screws got stuck, I didnt want to forcefully undo it as I may damage the laptop. Due to this laptop started overheating.
I created an RMA request, even noting that I'd repasted the HSF - they arranged the pickup, it got sent to the Netherlands and I got the laptop back a week later - with the entire HSF assembly replaced.
Very pleased :)
absolutly no idea about uk stock, I bought mine on the off chance of seeing it and thinking it was a great spec for the price. I must admit other than the day I found mine I have not been able to find stock at other retailers.
I have seen the 725 in stock here and there though.
Not good
Aye I agree. Its a shame really as its a decent design, spec and is pretty sturdy in comparison to some of the others on the market.
The only difference here when comparing vendors seems to be the support.
I think that if the colour wasn't so damn ugly it would be almost perfect appart from being pretty bent right now.
Thought I would post a little update seen as it’s been a while, so I had ordered the parts and last you knew I was waiting on them. Well our accountant was a little slow on getting the payment cleared abroad so it was only this morning that I got an email at 8:30 from Fred at MSI saying that the payment was there and he was ready to check for and send the bits.
Firstly let me tell you a few other things, where I have been using the machine after the drop I have managed to cause more damage to the hinges/screen mounts (snapped brackets) and also when disassembling the machine the track pad is super glued pretty seriously to the chassis meaning that removing without causing damage is not easy. Anyway a quick call in to Fred and the answer was
"Sure tell me the parts and I will attach them to your casing order for free"
So… on top of the order I have a replacement track pad, set of screen brackets and full set of rubbers.
Again on payment for the casing the service was top notch, he asked on colour, did I want any of the US colours, blue or silver. Seen as the touch pad at the top of the machine was still red I mentioned that red was the first choice with blue and silver close behind. 10 Minutes later I had another email from Fred telling me that the bits were on their way.
Top notch service each and every phone call - What’s better is that each time I have called (probably 6 or 7 times), the call has taken no more than a few minutes to talk to who I need to speak to and get a sensible answer.
