MSI HD 7850 Power Edition Twin Frozr IV OC 2048MB GDDR5 Overclocking
10 Sep 2012
Hi,
I'm new to overclocking and i'm not quite sure how to get the best results out if anyone could help me, i know the basics with MSI Afterburner and such but i'm really not good measuring the right voltage, fan speed etc etc to maintain the correct temperature. I heard the card has massive overclocking ability and i want to exploit that and get the best out of it as it's getting pretty bottlenecked on my motherboard M2N-SLI Deluxe at the moment. Which i am also looking to upgrade after christmas.
I also would love to overclock my AMD Athlon 64 X2 Dual Core 6400+ cpu as at the moment i'm looking to upgrade but have not got the funds available yet. Anyone who can help me overclock both to a stable ammount i'de really appreciate it.
This might help for your graphics card mate http://forums.overclockers.co.uk/showthread.php?t=18389760
I have a Msi 7950, i use Msi afterburner to overclock but AMD Overdirve is also just as good in the Catalyst Control Centre.
Just take your time and find a good Core overclock first on stock volts, by moving the slider in small steps 5 or 10Mhz at a time and then use a bench program like Heaven 3.0 to see if its OK.
Edit: Also move the Power Control slider to +20 this allows the card to use more Juice if needed.
As for your CPU i cant help as i Ive never had one :(
The guide above posted is brilliant helped me push my msi 7850 to 1340mhz and 5800 mem.
Best bit of advise I can give is to use the asus gpu tweak software and push the power bar up to around 4-5x just so it can draw more if it wants keeps it more stable:)
And of course putting a water block on it is definatly worth the investment:)
