- 11 Dec 2005
- Cheshire
Introducing two unique systems both featuring the awesome new Corsair 540 Cube case!
Both heavily featuring MSI and Kingston components, designed to work in tandem and deliver the absolute best gaming performance.
"Titan Swarm" Intel Core i7 4770K @ 4.4GHz Overclocked Gaming PC - Powered by Kingston & MSI @ £1,427.99 inc VAT
The "Titan Swarm" is a special Edition MSI & Kingston themed system based around the latest Intel Haswell platform. Packing the formidable Intel Core i7 4770K overclocked to a mighty 4.40GHz, the "Titan Swarm" has speed by the bucket load. Cooled down by the Corsair H80i CPU cooler, the "Titan Swarm" operates at optimal temperatures at all times.
The heart of the "Titan Swarm" is the MSI Z87 Mpower SP gaming series motherboard, allowing for ultra stable overclocks and equipped with Killer Ethernet as standard creating the absolute best gaming motherboard out of the box! Including one of the largest heatsinks ever fitted to a motherboard as standard. The MSI Z87 Mpower SP is also equipped with mind blowing 8 Channel HD Sound Blaster Cinema Audio enabling you to hear every single detail of the game leading you to victory!
Packing 8GB of Kingston HyperX NA'VI 1600MHz C9 dual channel memory, slow multitasking is a thing of the past, unlocking new doors into the world of fast computing. With distinct Black & yellow NA'VI branding and legendary Kingston reliability, performance is guaranteed. The MSI Z87 Mpower SP assists in keeping the memory at a consistent voltage to optimise the speed and timing accordingly, allowing for a totally smooth operation.
Continuing the theme, the you have a range of storage options to choose from. First and foremost the excellent Kingston HyperX 3K NA'VI SSDs, available in both 120GB & 240GB sizes. Complimented with a secondary SSD for RAID or even just a large 1TB HDD you can create your own storage combination to suit your needs.
Graphics duties are handling by the fantastic MSI Lightning GeForce GTX 770 2GB graphics card. Depending on your graphical usage you can opt to SLI to increase your firepower substantially. The GTX 770 2GB is the gaming card of choice delivering stunning DX11 visuals and bringing any game, even the most demanding, to its knees.
All of this is wrapped up into a Corsair 540 Cube case, decorated with Bitfenix Alchemy Premium White LED Strips for a truly distinctive glow.
Why You Should Buy This System
- A guaranteed 4.40GHz performance for the price of 3.50GHz
- Cinematic DX11 graphics provided by the epic MSI GTX 770 Lightning
- Precision built and cabled by Overclockers UK expert technicians
- 8 Hours stressed tested and quality controlled
- New Corsair 540 Cube Case providing Dual-chamber Direct Airflow Path™ design for outstanding cooling
- USB3, SATA 6GB/s, Intel Ethernet for next gen computing
System Specification
- Case: Corsair 540 Cube Case
- Power Supply: Corsair Enthusiast Series TX 850W V2PSU
- CPU: Intel Core i7 4770K 3.50GHz @ 4.40GHz Quad Core Haswell CPU
- Motherboard: MSI Z87 Mpower SP Gaming (Socket 1150) ATX Motherboard
- RAM: 8GB Kingston HyperX NA'VI 1600MHz Dual Channel Kit
- Hard Drive: Seagate Barracuda 1TB HDD
- Solid State Drive: Optional Kingston NA'VI SSDs
- Graphics Card: MSI Lightning GeForce GTX 770 2GB (SLI option available)
- Sound: Realtek Sound Blaster 7.1 Channel Sound (On-Board)
- Optical Drive: OcUK 24x DVD+/-RW SATA Drive
Service Package
- Full 24 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
Unique Kingston components combined with MSI performance for a true gaming machine.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
* No OS systems are fully tested with the same extensive methods as systems chosen with an operating system. Including tests such as CPU, memory and GFX stress tests. All no OS systems are formatted completely before shipping.
*Please allow 7 working days for your system to be built and configured. This may take longer during busier periods.
*Fast track service subject to current stock levels during busier periods.
*Please note, unless specifically stated in the specification above, gaming systems are not shipped with "free games" intended for component promotions.
Only £1,427.99 inc VAT.
ORDER NOW
"Titan Red Dragon" Intel Core i5 4670K @ 4.2GHz Overclocked MSI Gaming Edition PC @ £970.93 inc VAT
The "Titan Red Dragon" is a special Edition MSI themed system based around the latest Intel Haswell platform. Packing the formidable Intel Core i5 4670K overclocked to a mighty 4.20GHz, the "Titan Red Dragon" has speed by the bucket load. Cooled down by the Prolimatech Panther CPU cooler, the "Titan Red Dragon" operates at optimal temperatures at all times.
The heart of the "Titan Red Dragon" is the MSI Z87-G45 gaming series motherboard, allowing for ultra stable overclocks and equipped with Killer Ethernet as standard creating the absolute best gaming motherboard out of the box! The MSI Z87-G45 is also equipped with mind blowing 8 Channel HD Sound Blaster Cinema Audio enabling you to hear every single detail of the game leading you to victory!
Packing 8GB of Patriot Viper 3 "Venom Red" 1600MHz C10 dual channel memory, slow multitasking is a thing of the past, unlocking new doors into the world of fast computing. The MSI Z87-G45 assist in keeping the memory at a consistent voltage to optimise the speed and timing accordingly, allowing for a totally smooth operation.
Graphics duties are handling by one of a selection of fantastic MSI GeForce GTX 700 Series graphics cards. Depending on your graphical usage you can select from the following; a GTX 76-, GTX 770 or GTX 780 with the option to SLI to increase your firepower substantially. The GTX 780 3GB is the gaming card of choice delivering stunning DX11 visuals and bringing any game, even the most demanding, to its knees.
All of this is wrapped up into a Corsair 540 Cube case, decorated with Bitfenix Alchemy Premium Red LED Strips for an truly distinctive glow.
- A guaranteed 4.20GHz performance for the price of 3.40GHz
- Cinematic DX11 graphics provided by MSI GeForce graphics cards
- CPU: Intel Core i5 4670K 3.40GHz @ 4.20GHz Quad Core Haswell CPU
- Motherboard: MSI Z87-G45 Gaming (Socket 1150) ATX Motherboard
- RAM: 8GB Patriot Viper 3 "Red Venom" 1600MHz Dual Channel Kit
- Graphics Card: MSI GeForce GTX 760 2GB
Service Package
Unique form factor with superb MSI gaming hardware appeals to the hard core gamer.
Only £970.93 inc VAT.
ORDER NOW
Service Package
ORDER NOW
Service Package
ORDER NOW
