- 1 Jun 2010
- Bedford
Hi guys
I have overclocked 5850 to 900/1200MHz from stock 725/1000MHz and would like to test the overclock stabiliy. I did use msi kombustor and furmark in the past but don't think I used the right settings. Also afaik furmark and kombustor are same program with just different screens pattern.
Now the thing is I am still using 1024x768 res monitor atm
. However in near future I hope to get 1080p monitor for gaming.
First of all it gives me two options for render path OpenGL2 & OpenGL3. Afaik the ATI graphics cards use Direct3d and not OpenGL. So would it matter which one I choose.
Secondly which run-mode should I select?
Thirdly If I were to select 1080p res with full window enabled, would kombustor emulate those res?
What should I do about MSAA and for how long should I run the program?
(I know I am a bit of a noob in overclocking graphics cards department
many thanks.
. However in near future I hope to get 1080p monitor for gaming. First of all it gives me two options for render path OpenGL2 & OpenGL3. Afaik the ATI graphics cards use Direct3d and not OpenGL. So would it matter which one I choose.
)many thanks.
