MSI Mag 323UPF - worth it at £500?
24 Feb 2024
UK
I’m getting really confused about what monitor to go for in the mid tier 4k range.
MSI Mag 323UPF
Is this a good deal or a value trap?
Running with a 4070ti Super.
I mainly play Destiny 2.
Thanks!
Thanks for the link!
I find it very difficult to make the decision.
I tend to only play one game and all the detail of HDR this and HDR that goes way over my head.
All I want to know is whether it’s a good performer for FPS. Not hugely worried about colour depth etc…
I like a big screen as I currently have a 32” display hence looking at 4k.
Would I be better off dropping to say QHD and getting a quicker panel?
My budget is £500-£600.
Doesn't sound like having HDR is critical for your needs. If having the highest FPS is what matters the most to you have you considered looking at a 1440p high refresh rate eg. 240Hz monitor instead ? Your 4070ti Super would perform better at that resolution.
Yeah I have definitely thought of that but there are soooo many options and my head is mashed!
any suggestions on a good 1440p 240hz monitor at 32”?
I'm not well versed on high FPS monitors as it's not something that meets my needs ... I don't play competitive FPS games. But if I did, I'd be looking at the Alienware AW2725DF. At 27" a bit smaller than what you're looking for, and a bit above your budget at the moment because it's new. But I think prices will fall over the next 6-12 months as new monitors appear on the scene and supply increases. This one is 1440p, 360Hz and QD-OLED, so a bit of everything for someone who plays fast action games.
Thanks for the tip. More research for me.
