MSI Mag x570 Tomahawk VGA led
7 Oct 2021
North England
Hi I recently bought and assembled a new (to me) pc but I can't get it to post. Most of the parts were from the Overclockers clearance section and are B-Grade, but I was assured that the parts still function.
Parts I bought:
MSI Mag x570 tomahawk wi-fi
Amd ryzen 5800x
Crucial Ballistix 16GB DDR4 600MHz Dual Channel Kit
WD Blue 3D NAND 1TB M.2 2280 Solid state drive
Using an old:
Corsair VS650 gold power supply
Xfx r7800 graphics card.
I knew I had to flash the new BIOS to get the ryzen 5000 to work, that seems to be successful.
All fans power on and plugged in peripherals light up.
However there is 0 visual output and VGA light from the EZ debug shines. The video cards fans spin up but apart from that appears inactive.
I have done all of the usual testing procedures:
Test with only 1 ram, no peripherals,
Use older bios,
Reset CMOS. (Done both battery remove and short jumper)
Swap ram stick place.
Use a different video card.
Try a video card with no extra power requirements.
Try a different output(VGA, DVI, HDMI)
Cpu_Pwr, atx_Pwr and video card power all connected.
All with no change.
This leads me to believe it's a faulty motherboard but I don't know if I'm missing something? I know it's an old video card but I tried others with the same result. Plus according to MSI it should be compatible.
Thanks in advance.
Have you tried a vid card in the lower PCIe slot ? Tried with a different psu?
My instinct is saying that the pcie x16 slots are set to pcie 4 and the vid cards you are using are not compatable. Resetting CMOS should have reset that to pcie 3 so I may be wrong.
Also thats some slow ram dude, back to the old school DDR era with 600mhz :) . I know you missed the 3.
Thanks,
I had before but tried the lower slot again a bit more thoroughly. Strangely enough it seems worse, the boot LED turns on too.
I tried taking out the m.2 and replacing it with a SATA ssd, no change. The motherboard built in fan seems to stop to?
I tried resetting CMOS with it in lower slot, but no apparent change.
Id have to buy a new PSU to check it :/ might be someone near me I could borrow
Have you tried with the mobo out of the case ? could be a short causing an issue.
You have checked all the obvious stuff so other than different psu I am out of ideas.
I appear to have it half working now. I really don't know what I changed, I took it out the case and tested after reseating the CPU but I had done it before. Strange. Thanks for your help so far
I have video out and it working on an old ssd, but Windows is not recognising the m.2 drive? Any potentials
Is the m2 drive showing up in the bios maybe try the other m2 slot .
